Engine Really Need Replaced?
Old 07-14-2010 | 08:21 PM
Originally Posted by ljdiscovery
there was a 2001 or 2002 motor in Phoenix, listed on Craigslist over the weekend. 25k miles for $1500 as I recall. you might check it out. If it runs, it may save you tons of money and time. Phil
Except shipping that engine from AZ to AK is going to cost more than a new engine from the dealer. LOL
Old 07-14-2010 | 08:38 PM
AK Rover's Avatar
I've been looking everywhere I know people for an engine, including PHX. I have a friend that works for Alaska Airlines that may be able to ship an engine up here cheap if I can find one.
Thanks for all the info. The block tester in the video sells for $250 and since I don't plan to operate my own Rover shop I can't justify that kind of money. I was told a shop up in Anchorage sells Rover engines for $1900 but you only get a warranty if a licensed shop does the install.
Here's my next question, will the block from a GEMS motor work with the later Bosch heads and top end? I was thinking if I could find an older block from a D1 since the problem seems limited to the D2 I would just pull the current block and put on the heads and top end from the older engine.
Old 07-14-2010 | 08:48 PM
The sensors are different from the GEMS and Bosch engines so I do not know if it will work or not.
Old 07-15-2010 | 01:55 AM
AK Rover's Avatar
I had no idea the Bosch motors had the problems they do. Really glad I don't own a D2 now but still thinking of trying to track down a GEMS block and throwing back together with the Bosch intake and heads. I'm willing to take the chance since I'd be spending dad's money and not mine. Of course if it didn't work I would inherit a broken D2 and a big bill.
Old 07-15-2010 | 07:11 AM
Bundu's Avatar
Banned
The crank position sensor is different on Gems and Bosch, you will have to do some cutting and/or welding to fit a Bosch crank position sensor into a Gems block.
k75ssk
07-10-2014 06:37 AM
range_time
05-05-2010 02:19 PM
Manhattan
07-10-2006 10:44 PM
kfordric
02-20-2005 05:33 PM
kfordric
02-20-2005 05:33 PM
Quick Reply: Engine Really Need Replaced?
