Engine Rebuild: 4.6 components in a 4.0
Old May 10, 2019 | 07:55 PM
Extinct's Avatar
The 4.6 pistons have more dish to achieve the same compression as the 4.0 pistons, so if you use the 4.0 pistons you will get more compression. It will be ok, but you might need to run a high octane fuel to prevent detonation. I would think any good quality rings should be fine, if hastings are known to be a minimum gap try a better brand.
Old May 11, 2019 | 12:03 PM
robertf's Avatar
Originally Posted by Stephen Perez
In regards to vaseline, how does it ever dissolve in Engine oil? I feel like it will always be circulated in the system...
Dissolves just fine. RAVE even calls out this procedure for pre-serpentine belt v8.
Old Jun 10, 2019 | 06:10 PM
Tony Luna's Avatar
I ended up talking to a local shop who works on Bosch engines. Apparently Hastings piston rings are what he orders.
Im still trying to figure out if there is a size difference in pistons between the 4.0 and 4.6. Any guidance would be great!
i also ended up ordering a new Elbow for the coolant just because of the rust. I figure getting rust particles in the coolant isn’t the best thing for the engine
Stephen, any progress to report?
Old Jun 21, 2019 | 06:25 AM
Stephen Perez's Avatar
Unfortunately, I'm at a pause on this project due to work sending me overseas for 5 months last minute. I'll be tackling this once again in the fall. I'll be sure to update here once I'm back!
-Stephen
Old Apr 28, 2020 | 04:00 PM
Tony Luna's Avatar
-Stephen
Hey Stephen,
Did you ever get back to this?
Thx,
Old Apr 28, 2020 | 10:37 PM
Originally Posted by Tony Luna
Hey Stephen,
Thx,
I did and it was successful. I managed to get her up and running. Currently at 100 miles on the engine. After pulling the engine out twice (I may have forgotten to tighten down something behind the flex plate after putting it back in once) I have a minimal oil leak out the back which may be the crappy aftermarket Crucifix seals. The fan clutch might also be bad, but I’ll do a full write up with what pictures/videos I have and any lessons learned this coming weekend!
Old Apr 29, 2020 | 01:31 PM
Tony Luna's Avatar
Thanks - greatly appreciated!
I'm starting to order parts for my 4.0/4.6 build Bearmarch crucifix seals was one of the first items ordered.
Looking forward to the write up.
Old Apr 29, 2020 | 02:08 PM
Tony Luna's Avatar
Old Apr 30, 2020 | 04:53 PM
yep don’t make that mistake. I didn’t have time this week to work on my Rover so I ended up dropping it off at a specialist to do a post re-build inspection of her to ensure I didn’t royally mess anything up
Old Aug 31, 2020 | 01:54 PM
Tony Luna's Avatar
Hey Stephen,
Still running strong?
Waiting on my current motor to stop running so I can start the new build, but she just keeps chugging along...
