Engine replacement
Old May 8, 2026 | 08:54 AM
ericg's Avatar
Default Engine replacement
I'm looking at taking a 4.0 block and putting 4.6 heads and cam on it. Into my 03.
Does any one have a list of things that they changed out while doing this?
I've got the heads and motor.
so I'm planning on replacing.
Lifters
push rods
bearings
cam most likely will be a stock 4.6
timing chain and oil pump. I'll pull the front cover off my current 4.6 that has a 2 year old oil pump.
I'll probably do the sensors while I can get to them easy.
Possibly rings if needed
Am I missing anything?
Old May 8, 2026 | 09:41 AM
whowa004's Avatar
if you're doing that you might as well upgrade the cam..add crucifix seals to be replaced while you have oil pan off already.
Old May 8, 2026 | 10:43 AM
ericg's Avatar
All that will be done. Might as well try to get all the leaks taken care of while its out.
Old May 8, 2026 | 08:50 PM
Best4x4's Avatar
Heads on a LR V8 are nearly identical minus the following:
14 Bolt Heads
10 Bolt Heads
10 Bolts with SAI ports
There isn't a specific head for 3.9, 4.0, 4.2, or 4.6 engines.
Old Yesterday | 03:08 PM
jastutte's Avatar
i'll second upgrading the cam. i have Stage 2 and the power difference is noticeable even with 32" tires, a winch, and front and rear steel bumpers.
GavinC
Yesterday 08:48 AM
