Engine stalling after getting to runners temperature.
Old 08-29-2021 | 04:27 PM
Chesley's Avatar
Default Engine stalling after getting to running temperature.
Hello to all! I’m a new member of a couple of years and have only posted one thing. It was about my door lock system doing odd things. Turning off vehicle when running when hitting unlock from central switch. While turning rear wiper at the same time. All doors would lock, but only driver door unlocked every time. The rest every once in a while.
About a month ago, starting having issues with engine stalling after getting to operating temperature. Then finally stalled and did not start again.
After reading vigorously on here about diagnosing the no start, no fire issue. And changing out the CPS and checking fuses, relays, grounds, and pulse wires to coil packs.
Still no luck!
In one thread they talked about changing the interior fuse box out. So, I ordered one and received it today and got it installed.
Fired right up and running very good! Fixed the door locks and rear wiper issue.
I want to say Thank you for everyone’s knowledge on here! Hope this may help someone else.
The following 4 users liked this post by Chesley:
Daytoman (08-31-2021), Massrover (08-30-2021), Richard Gallant (09-01-2021), The Deputy (08-30-2021)
Old 08-30-2021 | 05:51 PM
The Deputy's Avatar
Glad to hear about a happy ending. Sometimes, a good bit of reading can save the day.
Rover on!
Chesley (08-31-2021)
Old 08-31-2021 | 06:28 AM
Daytoman's Avatar
Still no luck!
This place is saves a lot of people’s bacon! Glad you got it figured out! Thanks for posting up your fix!
Old 12-14-2021 | 10:35 PM
austinlandroverbill's Avatar
Chesley, where did you get the new interior fuse box?
Old 12-15-2021 | 04:13 AM
Chesley's Avatar
Default Interior fuse box
Goldwing Rover’s out of New York. United States
Old 12-15-2021 | 09:22 AM
It was used? I have never seen a new one for sale.
Old 12-15-2021 | 11:18 AM
Chesley's Avatar
It was a used one. My understanding is that they are checked to make sure they work properly.
Old 12-16-2021 | 08:32 AM
They say they warrant it for a year, so that's good. Already ordered one.
Fingers crossed: when dealing with "Lucas, the Prince of Darkness" and his English followers, it is important to have faith/hope,
Chesley (12-16-2021)
Old 12-16-2021 | 04:49 PM
Chesley's Avatar
Awesome!
The fuse block fixed many issues that I didn’t understand what was going on. Good Luck
Old 12-17-2021 | 10:33 AM
I hope it does the same for me.
In addition to the current engine "when warm" performance issue, my sunroofs randomly open when the vehicle is started or turned off, so I am hoping an under-dash fuse box swap fixes that problem as well.
Quick Reply: Engine stalling after getting to runners temperature.
