Engine Swap Options
Engine Swap Options
Are there any options for an 03 disco? Something like an lr3 or rover engine? I have some investigating to do before I decide a new engine is in order, but I wanted to know if there are options other than a disco 4.6 replacement. I'm assuming the new motor would need to be compliant with the d2 ecu.
on
You just haven't called the right places, http://www.roverlandparts.com/engine-complete.aspx
Here you are for $3250 on a pretested, inspected and guaranteed complete used engine.
on
Their engines are opend up, top and bottom and gone thru before crating them. You can't be what they have to offer anywhere. Course there is the other issue, your 03 with a good engine is worth around $6500 to $7000 on the current market and it would not be wise to do a repait that excedes the total valve of the trucak as a new engine will.
So you didn't read all they do with the engine before they decide to sell it, did you?
Oh well, I still have some things I need to do to try and diagnose my problem before deciding what to do. I'm just trying to get educated on the options. Thanks to all of you for your input.
