Engine Temperature 215-218* at idle
Old Jun 17, 2010 | 12:22 AM
Spencerfitch's Avatar
Default Engine Temperature 215-218* at idle
I would never know without the scan gauge. The needle doesn't move an inch in the 195-218* the temperature fluctuates.
Anyways I noticed today temperature was reaching 218* at idle. Revving the engine did bring it down to 204*.
My main question is this a little high even though its a very hot louisiana summer?
And how do I know if my clutch is locking?
I have been noticing the SWOOSH sound alot more within the past week or two. But im not sure what that means, locking/slipping.
Im changing the coolant tomorrow to get the coolant to water mix right.. Right now I think Im running about 75% antifreeze.
Old Jun 17, 2010 | 02:11 AM
cranky's Avatar
The fan will roar when it is engaged, quite when it is not.
That roar is louder than the engine on my truck. It only comes on on hot days when sitting in traffic etc. Usually quietens down before I get 300 yards down the road and the air moving through the radiator is enough to cool the sensor on the clutch.
________
Park Royal 2 Condo
Old Jun 17, 2010 | 06:31 AM
lipadj46's Avatar
Your temp "gauge" on the dash is nothing more than an idiot light. When it moves past the middle your truck would be severely overheated already. 218 F is about the top temp you should see after driving for a while then idling.
Old Jun 17, 2010 | 06:58 AM
vandev's Avatar
Default not so....
There is no idiot light..those are money lights...the sign that money is going to be extracted from your bank acount...they do have a idiot logo though...it's LR .....
Old Jun 17, 2010 | 07:15 AM
The swoosh sound means you have a coolant leak so find and fix that before you worry about flushing the system. I would suggest you replace the t/stat after fixing your leak, if your head gaskets aren't leaking then check to make sure both electrical fans are working, also the main fan which should turn with little resistance when cold and a lot of resistance when hot.
As mentioned your are running too hot and I wouldn't drive it till you fix the issue.
Old Jun 17, 2010 | 11:43 AM
hilltoppersx's Avatar
im with mike. you are running on the hot side and need to find your coolant leak and flush the system.
Old Jun 17, 2010 | 07:04 PM
What is the temp while driving?
Old Jun 17, 2010 | 07:06 PM
the swoosh is the fan....
During driving it is anywhere from 195-210*
Old Jun 17, 2010 | 07:23 PM
Your fine then.
When idling in 100+F heat with the a/c on its going to get hot.
Change the coolant though, you have to much antifreeze and not enough water, that can cause issues.
jhobbs1824
Dec 12, 2015 06:59 AM
bobalou
Engine & Internal
Jun 10, 2015 01:29 PM
Discolife
Dec 19, 2012 11:43 AM
scadjoey
Jan 9, 2008 11:19 AM
CoriolisSTORM
Mar 6, 2006 05:23 PM
