Engine / trans compatability question
Old May 3, 2013 | 12:48 PM
Coyote's Avatar
Default Engine / trans compatability question
Does anyone know if a 4.6 engine / trans / transfer case out of a 99 P38 Range Rover is the same as what is in an 03 Discovery? Reason being I can buy the whole set up for $250.00, (conditiion unknown) and I was thinking if it all fits, might be good to have and build up as a spare.
Old May 3, 2013 | 12:50 PM
Dan7's Avatar
The engine is the same. I just bought a 99 P38 and put it in my 04. It is likely therefore the tranny/X-fer case are the same as well, but cannot confirm that first hand.
Old May 3, 2013 | 12:57 PM
pinkytoe69's Avatar
I thought the p38 uses some sort of viscous TC? I think the lucky8 build thread addresses it.
Old May 3, 2013 | 01:46 PM
jafir's Avatar
Transfer case is certainly different. It's a Borg Warner and the drive shafts are on the left instead of right. Also if you're looking to just drop right in, you'd need to make sure the p38 engine is Bosch not Gems. Timing cover is different too. 99 p38 probably doesn't have SAI, 03 disco more than likely does. That means the heads are different and will need swapped.
Old May 3, 2013 | 03:41 PM
Stay away from that t/case. Have you considered modifiying your current t/case to a CDL, add the linkage and your done, By doing this you will have a well know t/case instead of an older one that would also need to be rewired for your solenoid.
gah964
Engine & Internal
14
Mar 1, 2014 04:57 AM
bates
LR4
Sep 20, 2013 11:15 AM
fishEH
Oct 18, 2012 12:42 PM
GATORPLANT
LR2
Mar 29, 2010 07:17 PM
2002 freebie se
Freelander
Jan 3, 2009 12:42 PM
