Engine wiring burnt out on the highway
Old Sep 22, 2012 | 09:08 AM
  #31
Racer X's Avatar
Get the splice kit at Home Depot, in the electrical department. You can find it with the crimp tools, butt connectors, coaxial connectors, etc...
Old Sep 24, 2012 | 08:01 AM
  #32
1988E30M3's Avatar
OP, thanks for this post. I checked my wiring this weekend and it was close to the exhaust. Had I not seen this post and checked maybe I would've suffered the damage on my disco.
I also took a good look around other wiring and found some that needed to be zip tied to prevent contact with hot engine parts. If, you haven't already done so, check your wiring.
Old Sep 24, 2012 | 02:01 PM
  #33
jfall's Avatar
Please - only solder!
never crimp.
If you insist on crimps, then solder the crimp after..
You should solder and have heat shrink tubing on it ready to be moved into place and shrunk on.
Old Sep 25, 2012 | 10:50 AM
  #34
slanginsanjuan's Avatar
the battery was fried. i still need to check it but the D1 battery works great in it.
soo all the small wires were soldered. 7 maybe.
the big was not soldered. it was partially cut and he didnt want to complete the cut and clean it because he would lose the "backbone" of the wire and many of the strands were still intact. he "put it back together" and rubber taped it and there seems to be no problem.
Should I make him redo it and solder it?
Glad you other guys are checking this on your rigs. Do you check the hard cooling system lines? You could learn from my huge FU if you replace them early.
Old Sep 25, 2012 | 11:40 AM
  #35
drowssap's Avatar
the large cable in your pix looks like the battery cable, is it?
Old Sep 25, 2012 | 11:50 AM
  #36
well i probably should know by now but i dont. its a power cable, multistranded copper about 3/8 inch thick. looks just like the battery red cabling I guess.
Old Sep 25, 2012 | 12:02 PM
  #37
more pics......
the first is a close up on red power cable. its "torn" 65% thru.
the second is repaired
the last is a close up on the power cable
Attached Thumbnails Engine wiring burnt out on the highway-torn-wire.jpg   Engine wiring burnt out on the highway-repaired.jpg   Engine wiring burnt out on the highway-power-cable.jpg
Old Sep 25, 2012 | 11:40 PM
  #38
Spencerfitch's Avatar
This is exactly where I think mine is starting to burn/ment/short
Old Sep 26, 2012 | 06:28 AM
  #39
drowssap's Avatar
thats you battery cable, replace it.
Old Sep 26, 2012 | 08:33 AM
  #40
maybe you should move and fasten it,
