Entering radio codes for '99 Disco I
Old Oct 26, 2007 | 11:09 PM
Haligan's Avatar
Default Entering radio codes for '99 Disco I
Got the code from the dealership but don't have directions as to what buttons to press to actually enter in the numbers. Is there a master button to press first and then enter the various numbers through the seek/ tune buttons, then another to accept each number? Thanks for your help!
Old Oct 27, 2007 | 12:17 PM
okdiscoguy's Avatar
Default RE: Entering radio codes for '99 Disco I
just use the staion preset numbers. If you get it wrong 3 times in a row, it locks up. You have to leave the ignition on and have the radio on for 1 hour. Then just enter the numbers nothing else.
I had to enter mine, and thought I could enter it from memory. nope....It locked up, and I had to let it sit in the driveway for an hour with the key on. sucks....
Old Oct 27, 2007 | 04:09 PM
Haligan's Avatar
The problem is, my presets only go to 6, but the code numbers go above 7, so do I press some presets twice?... do some of the presets represent higher numbers? etc. I read through all the other posts on the site concerning radio codes and nothing works. I've let it set several times to reset the incorrect entries.
When I punch in the numbers, will "CODE" flash, or display the numbers, or otherwise acknowledge my existence... other than the "beep, you've failed again!" Just looking for a little positive affirmation I guess. Thanks.
Old Oct 27, 2007 | 08:30 PM
okdiscoguy's Avatar
code will stay on there until the correct code is entered.
I would call the dealer back and see what they say. The numbers should only be 1-6
yoeman
Aug 5, 2023 11:01 AM
Rover De Land
Apr 5, 2013 03:02 PM
cheqbay1997
Oct 24, 2012 09:02 PM
ljdiscovery
Nov 6, 2009 03:11 PM
Steve B
Jun 25, 2007 08:54 AM
