Error Code 413
I have error code P1413. The scanner list this as Secondary Air Injector System Switching Valve A Circuit Open.
I just bought the car and it passed Calif smog check wihtout any problems lees than 300 miles ago.
2000 Discovery II 82,000 miles.
Now what do I do?
Thanks for the help,
Now what do I do?
If it doesn't rain all weekend I'll try and troubleshoot the problem a little more.
If and when I find the and correct the problem does the Service Engine Soon Light go off or do I need to manually reset it with an OBD Scanner.
The Disco is back up and running. I removed the Secondary Air InductionControl Valve and sprayed it with Sea Foam "Deep Creep" (multi-use penetrating lubricant and sensor safe air intake clearning system), let it soak for about 4 hours and then cleaned it out usingcompressed air it started to work.[/align][/align][/align]Thanks for the support.[/align]
Danny Lee 97 Disco
ROAMING WITH FRIENDS
Aug 26, 2012 06:23 PM
