Error Codes
Old Oct 25, 2005 | 07:31 PM
asterix's Avatar
7th Gear
Default Error Codes
Howdy kind folks,
I am an newbie here and would appreciate your suggestions.
I noticed the check engine and SRS lights on in my Disco II, so I stopped by an Autozone place and had the codes pulled. The following are the codes the ObdII scanner gave:
P1193 - ??????
P0158 - O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0441 - Evaporative Emission Control System Incorrect Purge Flow
I got the code meaning from http://www.obdii.com/codes.html
Any ideas as to what these are and what needs to be done to fix them? Please I am not mechanically inclined, so help break it down for this novice.
I just recently did an oil change, tune-up and had the fuel filter changed because the Disco was stalling and took too long to start............ a problem that is still occurring.
Thanks!
Old Oct 26, 2005 | 06:10 PM
forbin10's Avatar
Default RE: Error Codes
P1193=HO2S Heater Circuit Inferred Open Circuit, Downstream Sensors i got that from www.iequus.com/obd_def.asp that is all i can help you with
Old Oct 26, 2005 | 07:23 PM
mikemeyer0's Avatar
Chris-St Louis gave you all the info you need.
pixel
May 13, 2011 07:24 PM
caysteve
Freelander
Dec 9, 2008 10:58 PM
wetheww
Sep 27, 2008 08:41 AM
fresh2austin
Apr 30, 2008 10:38 AM
hollis
Feb 15, 2008 08:29 PM
