Error Codes - Where to Begin
Old Jul 1, 2019 | 02:18 PM
bjordan's Avatar
Default Error Codes - Where to Begin
Hi Folks,
Two weeks ago, I bought a second Land Rover Discovery II. The first one, a 2002, I bought 2 months ago. The new Land Rover is a 2004 HSE in good condition 111,000 miles, but had/has some mechanical issues. As expected, it broke down on the 6 mile trip home, in 5:00 rush hour traffic, blocking one of two lanes - until I eased off the road with my Dodge truck. So far, about what I expected to happen.
I had it towed home and a few days later, I swapped in a new Crankshaft Position Sensor. It started up, but runs rough when in park/neutral and especially rough when shifted into gear. But, I can at least move it around some and test drive it in the neighborhood. I have not done any other mechanical work to it, yet. I read the engine error codes yesterday and they are below. Given that there are 12 of them and the symptoms I described, what would be the top 5 or so codes to focus on first and what parts need to be replaced that are causing the codes?
P1884 Engine air intake temperature invalid No apparent effect. On Off.
P1451 evap emission control sts vent control valve circuit
P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
P1482 DMTL Heater power stageDrive cycle A:Signal out of range - below minimum
P0445 Evap Control System Purge Valve C Short
P0448 Evap Control System Vent CKT Short
P0102 MAF or VAF A Ckt Low Input
P0340 Cam Position Sensor A Bank 1 CKT Malfunction
P1300 1300 is random misfire
P0134 O2S CKT No Activity Detected
P0154 O2S CKT No Activity Detected 2/1
P0300 Random/Multiple Cyl Misfire detected
Thanks for the help.
-Burwell, in New Orleans if there are any other folks here from New Orleans
Old Jul 1, 2019 | 06:26 PM
Extinct's Avatar
Looks like a bad MAF sensor, easiest to start with that, nothing else will cause serious misfire. Start by getting a $5 ELM327 OBDII reader and the free torque app for android - chart the MAF sensor and the O2's. Post results here. We will go from there.
Old Jul 2, 2019 | 10:06 AM
bjordan's Avatar
Thank you Extinct! Just yesterday afternoon, the iLand diagnostics tool came in from Atlantic British that I ordered. I haven't even unwrapped it yet. I got it mostly to program key fobs for both of my Rovers.
Surely the iLand will chart the MAF sensor and the O2 sensors?? I hope it does.
I went ahead and got proactive and ordered a new MAF sensor and the 4 O2 sensors.
Old Jul 2, 2019 | 02:21 PM
bjordan's Avatar
I was able to play with the iLand diagnostic tool and graphs of the MAFS and both O2 up and down sensors are below.
The MAF spike is at startup and the drop of the O2 sensors is at startup. I ran the engine for about 60 seconds for the O2 sensors.
Old Jul 2, 2019 | 03:54 PM
KernowDiscovery's Avatar
Originally Posted by bjordan
Hi Folks,
Two weeks ago, I bought a second Lander Rover Discovery II. The first one, a 2002, I bought 2 months ago. The new Land Rover is a 2004 HSE in good condition 111,000 miles, but had/has some mechanical issues. As expected, it broke down on the 6 mile trip home, in 5:00 rush hour traffic, blocking one of two lanes - until I eased off the road with my Dodge truck. So far, about what I expected to happen.
What happened to your first 'Lander' Rover Discovery II? Do you still have it?
Sorry to hear that your Rover broke down in rush hour traffic - no fun when they have temper tantrums in bumper to bumper traffic.
Old Jul 2, 2019 | 04:49 PM
bjordan's Avatar
I still have the first one. I got it for $500. We have put in head gaskets, a new steel rear bumper, new front bumper, and more. It's a 2002 and running pretty well. I have an exhaust leak I need to get fixed at the near by muffler shop, but overall, it's doing well!! Still tweaking it, but it will be fine.
Old Jul 2, 2019 | 05:42 PM
Extinct's Avatar
Can't tell much at idle, you need to drive it see if the sensors respond to changing conditions.
Old Jul 2, 2019 | 08:43 PM
bjordan's Avatar
Thanks. That will take me a few days.
Old Mar 17, 2020 | 08:01 PM
Broken08's Avatar
updates?
Old Sep 10, 2020 | 11:08 PM
disc0_biscuits's Avatar
6th Gear
Originally Posted by Broken08
updates?
+1 (bump)
Asking for a friend
KlamathMatt
Apr 17, 2020 05:27 AM
Nick Hawks
Aug 19, 2017 03:40 PM
Cj7jed@gmail.com
Jun 13, 2017 09:11 AM
KlamathMatt
Apr 4, 2015 12:12 PM
OKCRover73107
Aug 6, 2011 09:47 AM
