Multiple codes all at once - why?
Old Apr 2, 2015 | 08:43 PM
KlamathMatt's Avatar
Default Multiple codes all at once - why?
Is there likey to be one thing that tripped these? They came on all at the same time. I replaced the front o2s. They cleared but came back two days later. Purge valve and MAF sensors on order....but not confident that suddenly all these sensors are bad . What would you do to clear these codes?
P0134 - O2 Sensor Circuit No Activity Detected Sensor 1 Bank 1
P0135 - O2 Sensor Heater Circuit Malfunction Bank 1 Sensor 1
P0154 - O2 Sensor Circuit No Activity Detected Bank 2 Sensor 1
P0155 - O2 Sensor Heater Circuit Malfunction Bank 2 Sensor 1
P0102 = Mass Airflow Circuit - Low Input
P0445 - Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0448 = EVAP system vent control circuit shorted
P0340 = Camshaft position sensor circuit malfunction Open/short circuit to vehicle supply or earth.
P1884 = (37) CAN message: Engine air intake temperature invalid No apparent effect. On Off.
Old Apr 2, 2015 | 09:43 PM
dgi 07's Avatar
My bad. Completelyrics forgot to respond to the other thread. before you did the O2 sensors, when did this happen. Because this reads like a combination of something unplugged or not plugged in all the way. We're you doing any other work? Running wires, close to a ground? EtC.?
Old Apr 2, 2015 | 10:08 PM
ls1morethanyou's Avatar
rats or squirrels ate your wiring harness?
Old Apr 2, 2015 | 10:47 PM
No worrie..dgi07...It's been two weeks since the codes sprung up....i wasn't under the hood or under the rig before these appeared. I'll have a go at looking at the wires/connections again. Engine struggles slightly when I turn the key over but nothing too dramatic...though noticeable difference compared to before the codes. Thx!
Old Apr 3, 2015 | 10:10 PM
dgi 07's Avatar
May want to recheck your wiring as LS said.. That's a lot of codes for one problem at once.
Old Apr 4, 2015 | 09:45 AM
Broken08's Avatar
I 2nd a bad connector/wiring harness maybe. Also check/clean your grounds. Is the voltage OK? how is the battery and alternator? If those things aren't getting sufficient power none of them will work right.
I say start with grounds and work forward.
And remember to update us
Old Apr 4, 2015 | 12:12 PM
Charlie_V's Avatar
I got a whole bunch of codes at once, some of which you list... it was a bad MAF.
adventure95004
May 9, 2019 11:51 AM
bladeski
Feb 10, 2014 03:50 PM
caneraiser
Oct 27, 2012 07:35 AM
Bryan H
Sep 8, 2009 12:08 PM
philhan
Feb 29, 2008 06:24 PM
