Evans Waterless Coolant
Have any you had any experience with Evan's Waterless Coolant? I did a quick search on the forum and did not see anything.
Home » Engine Cooling Systems
A buddy of mine read about it on at Triumph forum. Apparently it is not water based so less corrosion issues and has a boiling point of 375 F (beyond DEFCON 1 for our engines) and therefore has minimum pressurization (which I would assume would be better for our head gaskets).
Thoughts and opinions?
Thanks
RS
Thanks
RS
"site:landroverforums.com glycol"
it will only show results from the site you specify after the :
works for anything on the interwebs.
ZMonet
06-24-2016 04:00 PM
SuperiorCarCare
Detailing
01-31-2014 11:41 AM
aguison
11-18-2012 05:15 PM
