Evans Waterless Coolant
Old Jan 29, 2013 | 06:53 PM
Rearden Steel's Avatar
Default Evans Waterless Coolant
Have any you had any experience with Evan's Waterless Coolant? I did a quick search on the forum and did not see anything.
Home » Engine Cooling Systems
A buddy of mine read about it on at Triumph forum. Apparently it is not water based so less corrosion issues and has a boiling point of 375 F (beyond DEFCON 1 for our engines) and therefore has minimum pressurization (which I would assume would be better for our head gaskets).
Thoughts and opinions?
Thanks
RS
Old Jan 29, 2013 | 07:18 PM
buick215's Avatar
I first heard about the waterless coolant on JayLenosGarage but I have never used it nor do I know anybody that has used it. Seems like a good idea for classic cars that sit a lot and don't get used often.
Old Jan 29, 2013 | 08:24 PM
ghengis86's Avatar
All glycol, no water. There's a thread here that discussed this coolant prior, but it's no surprise the search function didn't show; it's a weak spot on these vBulletin boards.
Old Jan 29, 2013 | 09:19 PM
primussucks's Avatar
use google instead.
"site:landroverforums.com glycol"
it will only show results from the site you specify after the :
works for anything on the interwebs.
ZMonet
Jun 24, 2016 04:00 PM
SuperiorCarCare
Detailing
Jan 31, 2014 11:41 AM
MC04DII
Feb 13, 2013 08:44 AM
Rock Sing
Jan 18, 2013 02:17 PM
