Excess Cabine Heat / Electric Cooling Fan Failure?
Hello All,
I am trying to track down a source of excess cabin heat on the driver side of a 2004 Discovery.
If the electric cooling fan on the front of the radiator was not working could it cause excess heat buildup that would radiate heat to the inside of the cabin on the driver side?
There is a metal bracket to the right of the gas pedal that gets very hot and a lot of heat builds up in this area - my feet get very hot in shoes! One of the brackets for the drivers side seat also gets very warm.
There also seems to be a lot of heat buildup under the hood - more than usual.
My temperature gauge does not move, I have no codes thrown but the SRS light has now come on which may just be a coincidence.
I replaced my catalytic converters thinking that they may have been plugged even though I had no codes showing before. I thought this may have worked but to no avail.
Any ideas? Anything I should be looking for?
Hello All,
As said, could be missing heat shields.
Converters could be stopping up, but that would make engine temp go up.
Basically the cats are right under the driver and front passenger's feet. With a heat shield, aluminum body, and carpet being all that's between them and your feet.
My Disco does not run hot, but the previous owner put an extra set of rubber floor mats under the stock mats. It makes a noticeable difference.
I will be putting a radiant barrier under the carpet (and above headliner) after I fix a few other things. That will fix the heat problems permanantly
I have the same issue, however, I believe it is due to my own cheapness...
Let me explain, I replaced the heater core with a cheap brand from China. After doing this, I noticed a fair amount of heat coming from the back side of the heater core closest to my right foot. This only occurs when in ECON mode and when the unit is blowing ambient air.
My fix, that is on the backlog, take some kind of heat blocking fabric and stuff between the center console and drivers side heater core.
Not sure if this is the same issue that you are having but, wanted to highlight you are not the only one and it could be multiple issues.
Also note, my truck likes to run around 201 F
The AC in my 04 throws ice cubes, it's freezing cold.
There is also noticeable heat from the floor and roof in summer. A radiant barrier will fix that.
