Exhaust bolt sealer?
I believe it is type of loctite. But it would have to be high temp. The Rave just says to discard the bolts and use new.
1. Remove 8 bolts securing exhaust manifold and
collect spacers. Discard the bolts.
2. Remove exhaust manifold.
3. Remove 2 manifold gaskets and discard.
Reassembly
1. Clean exhaust manifold and cylinder head
mating face.
CAUTION: Do not use a metal scraper or
machined surfaces may be damaged.
2. Fit new gaskets, dry, fit exhaust manifold.
CAUTION: Ensure that link bar on gasket is
positioned below spark plugs.
LH bank illustrated
3. Fit spacers to new manifold bolts and, working
in the sequence illustrated, initially tighten bolts
to 15 Nm (11 lbf.ft), then finally tighten to 38 Nm
Reassembly
mating face.
LH bank illustrated
