Exhaust Issues
Exhaust Issues
I have a 1995 Discovery with all sorts of exhaust issues.
I have read different opinions on decating the car, some say the car requires backpressure?
I cannot afford new cats, so this is probably my only option... environmental problems aside... will decating my land rover cause any engine issues, They are clogged, and my idle is bad, and one rattles extremely loud.
RE: Exhaust Issues
My exhaust is leaking before the cats right now (repairable)
My passenger side manifold has a large crack (not repairable)
My cats rattle, and are clogged (not repairable)
My muffler has a crack where the pipe connects to it (repairable)
So I figured if I was gonna pull just cats I might as well get all I actually need... I can remove my old and install the new, no welding however
Just wondering how much it might cost to get the exhaust from a junkyard
RE: Exhaust Issues
Your manifold is repairable, they can weld that shut.
To have your "new" cats welded in is around $50.
I have no idea how much they are at a junk yard. You dont have to use LR ones, just make sure that you get the correct pipe diameter and length.
Have you looked on e-bay for new cats? I have heard that they can be had for pretty cheap.
Any year of a DI will work.
RE: Exhaust Issues
I'll check by a muffler shop first...
everyone tells me to dump the land rover... it's too expensive, but I keep getting deeper
I've redone most of the electrical (that is my specialty)
replaced radiator (who thought it was a good idea to put oil + tranny fluid through it )
replaced all vacuum hoses
fixed window ECU
added ipod jack to radio
replaced maf
replaced most fluids (everything but diff fluids)
And as we speak the land rover has a busted brake hose that I have to order from the UK (front left outer)
I also want to get 4WD Low / Diff locks working (I think solenoid is keeping 4WD low from working, and I have to keep trying to unfreeze diff lock lever)
the only thing keeping me going is the land rover love, and the fact that I know more issues will always arise so fix ASAP
fixed window ECU
replaced maf
