Exhaust leak
Do you have SAI (secondary air injection) on your Dll? There will be external tubes above exhaust manifold, if you do. They could be cracked, common issue. Also check all of the tubes and hoses on the system for leakage. If you don't have SAI or tubes/system seems okay...could be cracked exhaust manifold or head gasket leaking externally. Normally, a cracked exhaust manifold will quiet down some as engine reaches operating temps, while head gasket leak will be opposite.
Richard Gallant (09-06-2020)
