Exhaust Manifold Final Torque
Old Sep 1, 2018 | 09:54 AM
CollieRover's Avatar
Default Exhaust Manifold Final Torque
In the Rave Manual Torque Settings section the Torque for the Exhaust Manifolds is listed as 40 ftlbs. In the Cylinder head Directions it is listed as 28 ftlbs.
This is a pretty big disparity. I have been using 28 ftlbs, and it appeared that there was a bit of a leak in a couple of places. What do you guys think about going to 40 ftlbs.?
Old Sep 1, 2018 | 10:54 AM
Saturnine's Avatar
I think i did 40lbs on mine
Old Sep 1, 2018 | 10:56 AM
duscarter's Avatar
I'm glad you are asking these questions, as I prepare to put mine back together next week.
Old Sep 1, 2018 | 11:27 AM
No Doubt's Avatar
I didn't use a torque wrench on the exhaust manifold bolts.
I *did* tighten them in a pattern similar to the head bolts and made 2 passes.
You've got a lot of tolerance in those exhaust gaskets to forgive a lot of errors, for one thing, and if you have a leak there's always copper exhaust gasket sealant to slather on the outside.
Plus you can loosen and re-tighten those exhaust bolts multiple times, as desired.
Old Sep 1, 2018 | 05:14 PM
See you boys at 40 foot pounds.
Old Sep 2, 2018 | 07:30 AM
OffroadFrance's Avatar
Collie, if you can reach the manifolds easily after total assembly then do 30lb/ft and later when the engine has cooled down do an extra torque to 40lb/ft. Although it seems a very hefty torque on 10mm studs considering it has a laminated gasket.
Old Sep 2, 2018 | 07:44 AM
Thanks Offroad. I will do 30 and see how it feels.
Old Sep 2, 2018 | 01:57 PM
I'm a horrible person I just tightened them
Old Sep 2, 2018 | 02:00 PM
$%&. Now I feel guilty. I'll go to forty too if it makes you feel better. I don't think 40 is like, excessive.
Old Sep 2, 2018 | 03:15 PM
No I meant no torque wrench, just a 3/8 ratchet and they felt tight to me lol
