Exhaust manifold removal
As I recall you will need to use a 12 sided socket (they are a 12 sided bolt and the 6 sided socket does not fit tight), forget what the exact size is maybe 13mm as I recall. Spray them down with PB Blaster and start your truck so they get hot and use a breaker bar. Just go SLOW at first as you do not want to break them off.
ditto to all above......and I would add that you should probably use new bolts when putting everything back together. Voice of experience here.....I broke one of the old bolts without hardly any torque on it and stripped the threads in the head on one other. Get some grade 8 bolts, new gaskets, you'll be fine. FYI.......bolt thread size is 3/8-16 NC, and the added bonus.....with new bolts you can install "hex" headed ones thus eliminating the pesky 12 point issue next time. Good luck.
