Expansion tank cap pressure question
Old 02-25-2015 | 11:53 AM
completelymobile's Avatar
Default Expansion tank cap pressure question
I have searched the Rave, owner’s manual and the forum for the pressure rating on the correct cap for my 2002 Disco. 1.4 bar is stated in Rave and owners manual and when I convert to psi I come up with 20 psi. My cap is an aftermarket URO cheap part and it says 14 psi … so my question is what is the correct psi for my Disco? I’m doing high mileage tune up and thought this would be a good thing to update. Thanks in advance for any tips and or advise.
Old 02-25-2015 | 12:05 PM
drowssap's Avatar
i believe 14 psi is to low, i test my systems at 18psi
completelymobile (02-25-2015)
Old 02-25-2015 | 12:57 PM
I think 18 would be better ... who sells an 18 psi cap for a Disco II?
Old 02-25-2015 | 03:06 PM
OverRover's Avatar
You can get a 20psi STANT cap(# 10246) at any Advance, AutoZone, Napa, or... http://www.summitracing.com/parts/sn...ake/land-rover
or try AB, RN, L8, RovahFarm... OE # PCD000070
Old 02-25-2015 | 03:09 PM
OffroadFrance's Avatar
1 New Stant OE Replacement Radiator Cap 10246 | eBay
There ya go but it does say 14.0 imprinted on the cap
Old 02-26-2015 | 07:49 AM
drowssap's Avatar
there is your answer stant make two caps for LR a 14psi and a 20psi, you have the wrong one
Old 02-26-2015 | 07:51 AM
drowssap's Avatar
completelymobile;
I do not have a 18psi cap; I have a 20psi, but i alway stop just shy of the limit when testing .
AZRover
06-01-2015 05:47 AM
russburcham
02-13-2013 07:50 PM
aguison
11-16-2012 09:29 AM
JBEGIN
11-08-2009 07:03 PM
Quick Reply: Expansion tank cap pressure question
