Expansion Tank Replacement
Old Aug 16, 2012 | 08:28 PM
tflem1's Avatar
Default Expansion Tank Replacement
So I have an 03 DII which has a cracked expansion tank.
Biggest question is why is there such a huge price difference between these two tanks, and I am assuming I have to spend the $200 for the 03. They are not interchangeable?
Expansion Tank (Part # PCF101410) - Land Rover cooling/heating from Atlantic British
Land Rover Expansion Tank (Same Fit As Genuine Part # ESR2935) - Land Rover Engine Parts
Old Aug 16, 2012 | 08:40 PM
wilson96rr's Avatar
Land Rover lists two different part numbers, but all Disco 2s take the same tank.
Old Aug 16, 2012 | 08:43 PM
jafir's Avatar
they both should work.
Land Rover parts, spares, Land Rover accessories - Search results for PCF101410
Old Aug 16, 2012 | 08:47 PM
jafir's Avatar
also, the "old" part number is $37 at rockauto.com
Old Aug 16, 2012 | 08:56 PM
Make sure to buy a new cap and t/stat when replacing that container.
Old Aug 16, 2012 | 09:03 PM
tflem1's Avatar
Thanks alot guys, probably saved me $130
Old May 8, 2013 | 04:36 PM
CGHowell2's Avatar
5th Gear
Disco Mike. Is there something different between the two tanks that requires a new cap and thermostat--like stronger material, etc. Or is that just good preventive maintenance?
Old May 8, 2013 | 05:20 PM
Good maintenance. The caps age, and if you had Dexcool it can attack them. If the cap is no longer holding the speced pressure, then coolant can be vented while you drive down the road. Thermostat - a 180F soft spring replacement model will drop coolant temps across the board.
Old May 8, 2013 | 05:25 PM
G Reeves's Avatar
+2 on what disco mike and savanah have said. Be care full when taking the tank out as the plastic pipes will break as soon as you look at them. You can then go to the dealership for new one or do like alot of us do and get some rubber pressure hose and clamps.
Old May 8, 2013 | 08:54 PM
ZGPhoto's Avatar
Agreed, go with the 180 degree stat, here are some install photos to make it easier for you.
https://landroverforums.com/forum/di...ow-much-58878/ <Click that
