experience w/2" extended terrafirma fender flares?
anyone have these?
would love some good pictures and your thought on quality, fit, and finish.
also, how was install?
remove the old and direct fit replacements? are they sheet metal screws or drill with nut n' bolt attachment?
![Name: _12_zpsjzq9omql.jpg
Size: 13.1 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/36173d1501365601-experience-w-2-extended-terrafirma-fender-flares-_12_zpsjzq9omql.jpg)
trying to replace my weathered wheels arches and get nice upgrade at the same time...
Nah, going to put them on. Kinda waiting until I do my paint job. Also adding these:
https://landroverforums.com/forum/mo...g-up-d2-61521/
just got em...no instructions.
they look great...comes with a run of cut-to-fit gasket material and a bunch of sheet metal screws w/black caps.
I guess this is simple a test fit, pilot, and bolt down kinda deal...
anyone else install them before I have at it?
how was OE flare removal? they're just held on with tape?
The OE Flare removal is a MAJOR "female dog"
It might be bad if you are not worried about keeping them in good shape to refinish, but is still going to be hard.
Get a blow dryer, NOT A HEAT GUN, start at one end and warm up about 4 inches for about 3 to 5 minutes. Get a plastic door panel tool (harbor freight has them cheap) and work the corner loose enough to start shiming the tool behind it. start prying and pulling up and back at the same time. Helps if someone else can angle the hair dryer behind the piece once you get the edge up enough. If they can heat while you pull, it will be alot easier.
Carlos Man (08-11-2019)
