Extra Foglight Switch
Any auto part store stock them.
Size it according to your system ouput.
Take the total Wattage of all lights on the circuit and ÷ by 12volts = your total system amperage.
The relay should be atleast this size.
Ex. (4) 100W lights ÷ 12 = 33.3amps. You need atleast a 35A relay.
Another thing to consider is the gauge of your conductors "wires". This all depends on the total amperage and wire run length. Do some research on sizing conductors to be sure you have the proper size.
One more thing. You will need to add an inline fuse (calculate proper size) to the "+" positive terminal conductor.
Bobby
I have been looking for new front fog light switch and had bad luck with ebay ..also I think I TRYED to swap the switches it don't fit the plug
