Factory Clock
Old Dec 10, 2008 | 06:29 AM
dholland's Avatar
Default Factory Clock
I have a 02 D2...it has the factory clock, which I am sure is standard.
Should this clock have a back light at night? Mine can only be seen during the day, it is pointless after dark.
Old Dec 10, 2008 | 07:27 AM
AK Rover's Avatar
Default RE: Factory Clock
Yes, the clock should light up with the other dash lights. There is a bulb in the back of the clock that need to be replaced. Remove the switches below the clock then use a flat head screwdriver under the bottom of the clock to release the tabs that hold it in place.
Old Dec 10, 2008 | 09:30 AM
apcollin's Avatar
there's a picture with description on how to remove it on atlanticbritish.com
might be of help.
i have the same problem but i've been too lazy to do anything about it for over a year
Old Dec 10, 2008 | 09:00 PM
http://www.roverparts.com/TechTips/C...eplacement.cfm
Its the same for a DII.
Remove the bulb and buy a new one at your local autoparts store.
Old Dec 11, 2008 | 06:45 PM
DDP's Avatar
DDP
i removed my clock last night found a bad diode going to replace this weekend -use a test light and see if you have power on the contact strip where the bulb housing makes contact if not then bad diode
Old Dec 18, 2008 | 04:40 PM
dholland's Avatar
Replaced it....wow, never new a $7 fix would be so nice!
Old Dec 18, 2008 | 05:55 PM
Jst4fun's Avatar
For anyone else reading:
1 remove cup holder tray (4 philips screws behind ash tray and coin tray, two per)
2 push old credit card, one on top, the other on the bottom of clock.
3 pull clock out
4 bulb is in back, turn ccw quarter turn
5 remove
6 reverse order for install
Enjoy
Nick
tjhappel
Feb 20, 2011 07:54 PM
AzCamel
Jun 14, 2005 08:39 PM
JA-NH
Jan 22, 2005 02:49 PM
JA-NH
Nov 23, 2004 01:40 AM
JA-NH
Nov 23, 2004 01:38 AM
