Factory heavy duty springs
Does anyone have the factory part number or color code for the D2 heavy duty springs? Rovers North sells them in a kit with shocks but they don't list a number for the springs they use. I'm not looking to lift my D2 much due to garage clearance, I just want to get rid of the sag and be able to use a 32" tire. The shocks on my D2 have been replaced so I'm not looking for a whole shock/spring kit.
Here you go...
http://www.discopedia.info/index.php?title=D2Coils
Probably more than you ever wanted to know about Disco springs
I'd just google the different coil numbers to see which are HD...
D2Coils
There are a lot of different options on the spring front for OEM Parts.
Standard RH Drive vehicles Pre-03 Model year, you had 9 Coil springs with a free length of 385mm made of Carbon Chrome.
From the 03 model year would be fitted with either Grey/Orange and Yellow/Grey or Pink/Grey and Brown/Orange if they are a 5-seater.
The uprated version is for the 7-seater weight, and is Green/Grey and White/Grey. The later ones are all Silicon Manganese.
Brown/Orange is 8.73 Coils for 384.7mm free length.
Grey/Orange is 8.73 Coils for 392mm free length.
Yellow/Grey is 8.73 Coils for 376.6mm free length.
Pink/Grey is 8.73 Coils for 400.3mm free length.
Green/Grey is 9.10 Coils for 395.2mm free length.
White/Grey is 9.10 Coils for 380.6mm free length.
Front springs upto 03 Model year were 7.6Coil/377mm on petrol (pink/orange) and 7.6Coil/383mm on Diesel (white/purple).
Post 03 there were a new range of springs to allow for the 4.6L petrol, winch and trim height variations.
All were made from Silicone Manganese.
Standard Fit RH/LH
7.4/378.4mm (Yellow/Purple) & 7.4/365mm (Blue/Purple)
7.4/387mm (Grey/Purple) & 7.4/373.8mm (Purple/Purple)
7.4/394.6mm (Yellow/Orange) & 7.4/382.6mm (Green/Orange)
If you had Yellow/Purple and Blue/Purple fitted you should fit Yellow/Orange (7.4/394.6mm) both sides for a Winch.
If you had Grey/Purple and Purple/Purple fitted you should fit Green/Orange (7.4/382.6mm) both sides for a Winch.
If you had Yellow/Orange and Green/Orange fitted you should fit Pink/Brown (7.6/405.6mm) both sides for a Winch.
Pink/Brown are the hardest/tallest you can get on the front OEM.
Part numbers are as follows and are all for RHD Vehicles.
FRONT SPRINGS
RH V8 to 03 Model Year - REB101340
LH V8 to 03 Model Year - REB101330
RH TD5 to 03 Model Year - REB101341
LH TD5 to 03 Model Year - REB101340
RH Yellow/Purple - REB000310
LH Blue/Purple - REB000320
RH Grey/Purple - REB000330
LH Purple/Purple - REB000340
RH Yellow/Orange - REB000350
LH Green/Orange - REB000360
BOTH SIDES Pink/Brown - REB000490
REAR SPRINGS
RH to 03 Model Year - RKB101101
LH to 03 Model Year - RKB101100
RH Green/Grey - RKB000340
LH White/Grey - RKB000350
RH Grey/Orange - RKB000310
LH Yellow/Grey - RKB000320
RH Pink/Grey - RKB000380
LH Brown/Orange - RKB000300
Standard Fit RH/LH
FRONT SPRINGS
REAR SPRINGS
Because I wanted to see how much I could lift it using OEM factory pieces and I get a price break at the local rover dealer because I work at a shop. Plus my D2 has brand new bilsteins and I'd rather not buy a whole kit of shocks and springs. My main goal is to just be able to run a 32"-32.5" tire without it ripping the front fender liners out. I don't mind minor rubbing at full lock or full compression. I just don't want it to rub so bad it pulls the plastic bits off the rover.
Blakesrover
02-20-2013 10:31 PM
honda50r
08-20-2012 04:42 PM
