Wiper help for Disco II?
Old Nov 16, 2010 | 09:12 AM
ehill03's Avatar
Default Wiper help for Disco II?
Hi folks- can anyone recommend a set of new wiper blades that will fit my '00 Disco II? I have heard good things about the Bosch Icon series but also silblades- but i'm not sure they are compatible with my year model w/o making modifications to the arms. I'm not very mechanical & it'll be my first winter full-time in the mountains so I'm looking for something that will excel in 'extreme' conditions. I was told at my local auto parts store that the bosch icons (422a & b) would not fit.... any feedback or advice for something I can pick up that will be good for winter but not require major adjustments?
Many thanks in advance!
emily
Old Nov 16, 2010 | 09:18 AM
You only have Sill Blades or factory blades to pick from unless you replace those old tired D2 arms out for a new set of D1 arms that offer a lot more glass pressure and then you can install the new Bosch blades.
Old Nov 16, 2010 | 09:27 AM
ehill03's Avatar
Thanks, Mike. Do you have any feedback on the Silblades? I noticed you're in Denver- I'm up in Routt county & this weekend's dump made me realize I probably should have wrapped this up in October. I've had folks recommend swapping out for the DI blades- is this something that is spendy? Could I do it myself? I'd prefer to keep my investment small, but if it's a modification that will pay off in spades I might be able to be talked into it.
Thanks again,
emily
Old Nov 16, 2010 | 09:34 AM
I ran Sill blades for years till my arms wore out and spent $17 a piece for new D1 arms and 5 minutes to install them. I currently run the Icon blades which are the greatest.
Old Nov 16, 2010 | 09:48 AM
hilltoppersx's Avatar
im with mike i run D1 arms with silblades on my disco, but my DD has the bosch icon's and they are superior.
Old Nov 16, 2010 | 10:43 AM
ehill03's Avatar
Ok- sounds like swapping out the arms might be worth looking into. Any suggestions as to where I can get a good deal on a new pair of D1 arms- or used, if they'd be significantly more economical & about as good as a new pair?
Thanks again for all the feedback.
Old Nov 16, 2010 | 12:38 PM
D2's Avatar
D2
Got my D1 wipers at Rovers North on sale , don't forget the bolt caps.
Prior to that I removed the plastic clip on the OE arm and ran a bolt thru the middle with nylock nuts, it became hard to find replacements with a skinny profile to fit into the arm, and then you had to ream out the center hole on some brands.
So.. I gave up on that mickey mouse !#$% and bought the D1 arms
Old Nov 16, 2010 | 12:44 PM
yloDiscoII's Avatar
I'll just chime in with another recommendation to do the swap to DI arms. I got mine at a local yard for $40 for the pair, but you can get them at AB, Rovers North, the dealer, the list goes on...
It is a night and day difference...then just get a 19" blade for the driver's side, and an 18" for the passenger side and you're set. The swap will take you all of 15 minutes, and you'll be glad you did.
Old Nov 16, 2010 | 01:45 PM
talk to will tillery at www.roverparts.com
Old Nov 16, 2010 | 07:31 PM
I also have DI wiper arms.
