Factory Land Rover front prop shaft grease question
Hello!
I recently purchased a 2004 Discovery that had a broken front prop shaft. I replaced the prop shaft with a new factory land rover shaft assembly and was looking at the RAVE manual for maintenance recommendations on the shaft. In the manual it makes mention to grease the sliding section of the prop shaft but makes no mention of greasing the front universal joint. Is the front universal joint a factory greased and sealed unit like the rear hookes joint?
Thanks!
Thanks!
Our 2003 had the original factory front drive shaft and it was non greaseable, except spline shaft/slide. So, if you bought a factory replacement...l'd assume it would be the same.
Rear drive shaft has a greaseable u-joint in the forward joint (behind parking brake drum).
Brian.
Brian.
I see that it does have a zerk fitting for the front u joint but find it odd that the repair manual makes no mention of ever greasing it. I'm also curious as to if the factory prop shaft came greased or if I should grease it and if it requires routine greasing.
It mat be that someone in Solihull figured it out too and they are now using serviceable U joints
Just grease everything front and rear as much as possible. I've had 2 fail on me throughout the 3 years I've owned it. Once when I got it. Then once last week. Autozone carries a kinda junky one BUT lifetime warranty
other mfg also make some other high dollar ones. Especially grease after high water! Grease grease grease!
other mfg also make some other high dollar ones. Especially grease after high water! Grease grease grease!I believe the original factory prop shafts had sealed U joints, and that's one of the main culprits leading to sudden and catastrophic prop shaft failure. If the factory units didn't have Zerks, the RAVE manual won't mention lubricating.
