Which Fan Clutch?
Old 02-26-2019, 08:00 AM
DISCOFETA's Avatar
Default Which Fan Clutch?
Hey folks -- I a going to end up doing it right...
I am reaching out to vendors to locate a new Airtex Water Pump with the brass impeller (they stopped making them).
I have read a lot of info on here that the Duralast 180 Thermostat right from AutoZone works just fine.
As for the fan clutch... the price differences I see online are huge.. AB has it for $200 while AutoZone has it for $55.
Is it really justifiable to spend $150 more on the one from AB?
Old 02-26-2019, 09:02 AM
JUKE179r's Avatar
For my V8 I've got the Hayden premium fan clutch #2781 for $28 at RockAuto. Works great.
Old 02-26-2019, 10:08 AM
Best4x4's Avatar
Received 2,272 Likes on 1,676 Posts
Hayden 2991 & Dorman 620-112 fan blade work good, but I’ve also used the fan clutch from auto zone. Works fine!
Old 02-26-2019, 07:23 PM
GCBurke's Avatar
I have an 03 so Im going with the 2991 on a 02 fan. Airtex WP and 180 inline tstat for me too.
Black Dynamite (07-26-2021)
Old 02-26-2019, 07:48 PM
Best4x4's Avatar
I don’t mind the 99-02 OEM fan blade, but 25.00 for a new Dorman 620-112 vs 60-75.00 for the LR blade = it’s just a fan blade & I’ll spend the extra $$ on other stuff.
Either way it’s a much better setup vs the 03-04 $$$ one piece unit.
Old 02-26-2019, 08:10 PM
GCBurke's Avatar
I picked up a used 02 fan for $30 local but yeah the average price is 50-75 shipped used.
Old 02-27-2019, 10:53 AM
DISCOFETA's Avatar
My model is a 2001. Do I need a new fan? I thought I can just change the "clutch". I am unsure which one to get and am unsure if the price differences really represent quality. That's what I am trying to figure out here. Thanks.
... for example: https://www.ebay.com/i/162519496135?ul_noapp=true
Is this ok to use? Is the autozone one ok to use? Or is the a real difference with the one on Atlantic British?
Old 02-27-2019, 11:17 AM
Best4x4's Avatar
Yep you can re-use 99-02 fan blades. 03-04 are the one piece units. Auto Zone Fan Clutch is made in the USA & has worked fine for me (bought 3-4 of them so far).
Old 04-02-2019, 06:06 AM
DISCOFETA's Avatar
When changing out the fan clutch on an 01 disco II, do you need to put loctite on the bolts that attach the clutch to the fan?
Old 04-05-2019, 12:21 AM
DavidOHendo's Avatar
Banned
That dorman fan blade is made of plastic .. do you know of any metal fans that work with the 2991 ? I don't have an uppershroud. I cut it out.
Quick Reply: Which Fan Clutch?
