Father of a Disco owner who needs help
Hey everyone. My son just bought a 2000 Land Rover Discovery 2. He loved it the first day he had it. Until he went to get it checked for emissions to get it in his name. He had the problem with no voltage to the obd2 port. He had to remove a bunch of hacked in wires for extra power ports. It blew a bunch of fuses. He replaced the fuses. Now it will not start and it wont shift out of park.
I have searched and read the forums. He has brake lights. He does not have turn signals. He has tried the key in the door lock and unlock 3 times. I am a mechanic but have not really worked on Land Rovers. Add to that he is stationed at Kirtland AirForce base in Albuquerque New Mexico, and I am in Pa. If anyone is close by to him and could maybe take a quick look at it and see if they see something obvious causing his issue I would really appreciate. He does not have much money obviously on E-3 military pay.
I will be buying one as soon as I get a good deal on one here in Pa, we intend to build them together ( at the same time anyway). I work at a garage and I am a welder/fabricator as well and would be more than willing to help anyone out here in Pa that needs a hand
Thanks from a frustrated Dad
http://macassemble.com/lrm/discovery...20Diagrams.pdf
May take you a few hours (or days depending how bad it is) but grab a multimeter and start tracing using the diagram above. Check all fuses (internal and under hood).
Guys, would that be a case similar to mine where there was an aftermarket security kill switch installed. Car won't start without the key plugged in. To do it, they do I know not what with the regular security systems. Maybe when it was sold they simply took it out and tried to wire it back originally without having it reprogrammed?
We thought about taking mine out but decided it wasn't worth the risk of it killing the whole system.
What does it do when you try to start it?
Does it turn over?
Does it start and die?
If it doesn't turn over, he'll need to track down why. If it does, first thing to check is that it's getting fuel.
With all of the wiring isues he has, anything is possible. It's also possible that the theft alarm has activated, disabling the engine controller.
Does it turn over?
anti theft
I thought the same thing and took the "key" out of the antitheft not knowing what it was. It is a simple device that cuts power if the key is not in. However it is programmed into the vehicle. Mine has one that says silence on the key.
