fault code 0441
Old Jul 3, 2007 | 06:56 PM
rravenn13's Avatar
Default fault code 0441
Can anyone help me with this code?
Thanks!
Old Jul 3, 2007 | 08:10 PM
okdiscoguy's Avatar
Default RE: fault code 0441
P0441
Generic
Evaporative Emission System Incorrect Purge Flow
Check your gas cap, Then check your vacuum lines.
Old Sep 1, 2023 | 07:40 PM
dgtrawick5's Avatar
Default Medium rough idle with P0441
So since getting the P0441 code around March of this year. Replaced purge valve with new (Bosch). Cleaned maf and IACV. Also had my mechanic change all plugs, wires, and both coil packs. The code has recently come back and he’s doing a smoke test on it tomorrow. Could the P0441 be causing the rougher idle? I will say it’s worse after driving a couple miles and sitting in gear at a red light. Anybody have any idea what else could be causing the rough idle???
suntreemcanic
Nov 13, 2021 09:15 AM
The Ocho
May 14, 2021 12:40 AM
Disco Britt
Nov 7, 2015 11:28 PM
jbarrios60
Mar 28, 2012 04:12 PM
pimnmike
Jan 27, 2011 01:00 AM
