Weird noise coming from front drive, pulley?
Old Aug 30, 2023 | 10:18 AM
aututto's Avatar
Default Weird noise coming from front drive, pulley?
I have this weird groaning/buzzing noise coming from the front belts (video attached). It sounds like a pulley or maybe PS? I flushed the fluid on the ps a couple weeks ago to try and help but still there. Can’t be heard from in the cabin, a little noisy on startup but can barley be heard once warm with hood closed.
https://youtube.com/shorts/UMGlAyZKg...5fWxAXpNYAfDan
Old Aug 31, 2023 | 01:00 PM
Harvlr's Avatar
The two things I would do are 1, use a stethoscope to try to hear where it’s coming from and 2, remove the belt and try spinning each pulley to see if one is noisy or feels wrong.
Old Sep 1, 2023 | 01:54 PM
nashvegas's Avatar
Sounds like one of the idler pulleys. (easily replaced just get the exact right size, there are a couple). Or power steering pump bearing gone bad. You don't have ACE so it's not that !
Old Sep 1, 2023 | 07:46 PM
JohnZo's Avatar
Default Doctor doctor
If you don't have a stethoscope, a 3/8 or so tube or hose can work. Clean end goes in the ear.... Just be super slow and steady poking around a running motor. Mind the fan blade. A short length of metal tubing in the business end aids accurate placement.
jahummer
LR4
Sep 29, 2021 03:28 PM
sayeedA
Feb 27, 2014 08:10 AM
FlyingZebra34
Dec 22, 2012 04:15 PM
G4-Rover
Nov 29, 2011 04:51 PM
DiscoIIBrandon
Feb 7, 2011 08:29 PM
