fault code 1316, misfiring
Old Aug 25, 2007 | 01:43 PM
FJL's Avatar
FJL
Default fault code 1316, misfiring
I have a 96 Disco. Repaced the oxygen sensors bur still misfiring. Fault code 1316 (excessive emissions) shows on the scan. Any ideas what I should check for next?
Old Aug 25, 2007 | 01:46 PM
Darover's Avatar
Default RE: fault code 1316, misfiring
How old are your spark plug wires???
Old Aug 25, 2007 | 02:33 PM
FJL's Avatar
FJL
plugs and wires are new
Old Aug 25, 2007 | 10:04 PM
ajh's Avatar
ajh
Check the spark strength, if a coil is going you'd see misfires, after that... well, your ECU I guess but coils is more likely.
Old Aug 26, 2007 | 07:47 AM
02 sensors were not the cause of your mis fires, what brand of spark plugs and wires did you use, what octane gas do you use?
You may want to recheck it for any more fault codes and get back to us.
Old Aug 26, 2007 | 09:48 PM
FJL's Avatar
FJL
Checked wires in the dark..they are arking. I'm going to purchase the Magnecor 8mm wires and see if that makes a difference
Old Aug 27, 2007 | 07:23 AM
It will make a hugh difference.
Old Aug 27, 2007 | 08:06 AM
chargersfan's Avatar
The magnecor are awesome I put them on this past weekend and wow what a difference! Hughly recommend
Old Aug 27, 2007 | 01:30 PM
bigugly82's Avatar
PM to chargerfan
Old Oct 27, 2008 | 05:44 PM
JoeyDisco96's Avatar
So is the code gone?
