A Few Things About My 95 Disco
I'm trying to kill a few threads with one stone here.
First off, the owner before me replaced the distributor and put in STI wires and crappy plugs, I am getting code 40 which is misfire in left bank, would new better plugs stop that? I will get magnacore wires when I can afford them but for now will stick with whats there.
Second, a couple lights in my dash console went out, is it easy to get off? I have not done extensive looking around but am just wondering if it is a weekend project or a night after I get off work project.
this next one is about my headlights, I have the standard 95 disco headlight but have seen some of the newer ones and their projection heaven headlights and I was wondering if there is a conversion kit for such a thing?
it is starting to get colder here in oregon and the disco is starting to have a more difficult time idling in the morning, is there an easy way to up the idle? because every once and a while when shifting it into reverse to back out of the driveway it will die.
ok, I think that is all I need for now, but knowing that I have a disco I will keep you posted on other issues.
thanks all!
thanks all!
thanks all!
thanks all!
About the idling, start the cheap and easy way, and take off your idle air control (IAC) and spray the hell out of it with some carb cleaner. That might help.
I've got my cente console apart now, among other things to replace a bulb. As long as you follow the instructions in the book or rave manual, it goes fairly smooth. The bulf I'm working on is for the heat control head. It's a 1.2 watt that's marked "OS12 1.2". Hope that helps. Where in Or are you? In in Lincoln City... Rain tomorrow! Woo Hoo
Jim
Jim
gavone1976
08-23-2013 09:01 AM
silar
08-14-2013 06:30 PM
rvrguy
06-18-2008 03:21 PM
gseitl
10-21-2007 02:14 AM
