Figured out my bank 2 knock sensor code problem. How to fix.
Old May 22, 2023 | 12:04 PM
cerpindicular's Avatar
Default Figured out my bank 2 knock sensor code problem. How to fix.
The problem is some chuckle f@$ck removed it. One by the starter. I cant seem to locate the plug for it so i can replace if. They also took the heat shields which i didnt know were a thing it was missing and needed until i satarted to check it out. Anyways...where should the plug come out of the harness at?
Old May 22, 2023 | 02:40 PM
Best4x4's Avatar
If I'm not mistaken it runs down with the main starter cable/12v wire then branches off to the knock sensor. Or it runs down the coolant pipe in that loom and then to the sensor. I can look when I get home. I know drivers side runs under AC bracket past water pump & down to the sensor.
Old May 22, 2023 | 02:41 PM
Extinct's Avatar
Comes out of the harness near the alternator. Special shielded wire. Take special care repairing it, best to get a piece of harness off a breaker and splice it in.
Old May 22, 2023 | 06:02 PM
my problem now is after fixing the wire (i think) the damn thing will now crank. No power through the signal wire. I can jump the starter with the key on an it will fire up
Old May 22, 2023 | 07:54 PM
Extinct's Avatar
Ohm it out from relay to signal wire, and chekc if you have voltage at teh relay.
Old May 22, 2023 | 08:21 PM
Well that was dumb...it starts now
Old May 22, 2023 | 08:22 PM
i dont want to talk about it...lol
Old May 23, 2023 | 11:47 AM
does the harness for the knock sensor go back to a plug anywhere? There is and 02 at the nearby u pull yard and I was wondering if I could just get the whole harness instead of trying to splice it.
Old May 24, 2023 | 08:37 AM
Extinct's Avatar
Had to repair one recently, they do not go back to plug. Best to cut a long length off of u-pull-it truck and splice in. I soldered my connection to make sure it was secure.
Old May 24, 2023 | 11:36 AM
ok thanks for the info. Guessing I need to seperate the shielding from the regular wire and splice both
