FILTER
Old Feb 23, 2008 | 11:15 AM
Default FILTER
OK, I have been having problems with not getting any replies from the forum.
I had noticed that somebody else was having the same problem, well I figured it out, all the replies were going into my spam folder.
So if anybody else is having this problem check your spam filter and change the setting, I turned mine off.
Old Feb 24, 2008 | 08:56 AM
jairocol's Avatar
Default RE: FILTER
Spike555, this is jairocol that person who have the battery/alternator issue.
I tried the connections based on your Pics and I still have the issue.
I took few Pics to the alternator belt and I need to sendit to you to check if this is ok or it is the problem .
But I am having problems trying to download the Pics. (problems problems problems).
Old Feb 24, 2008 | 09:07 AM
Default RE: FILTER
jairocol-read the second page of "disco 1 overheating", I wrote to panos and told him how to do it, so rather that type it out again...call me lazy, or call me late for church...
If your belt is routed wrong it wont turn the alt fast enough, or it might be turning it the wrong way.
Old Feb 24, 2008 | 09:54 AM
jairocol's Avatar
Default RE: FILTER
Old Feb 24, 2008 | 09:57 AM
jairocol's Avatar
Default RE: FILTER
Old Feb 24, 2008 | 09:59 AM
jairocol's Avatar
Default Battery alternato issue
Old Feb 24, 2008 | 10:03 AM
jairocol's Avatar
Default RE: Battery alternato issue
Old Feb 24, 2008 | 10:05 AM
jairocol's Avatar
Thank you spike555. Photobacket is a good web. I was slow to learned how to use it.
Check the pics please and give me your opinion about it.
Old Feb 24, 2008 | 12:14 PM
Your belt routing is wrong. It goes over the alt, down under the water pump, back over the power steering pump, under the crank pully, over the belt tensioner, over the A/C and then back over thr alt.
Old Feb 24, 2008 | 12:16 PM
I am willing to bet that the belt is slipping on the alt and therefore it isint charging.
