Final Straw....
Old Jun 4, 2010 | 03:44 PM
Eak69's Avatar
Default Final Straw....
Welp. I have owned the now 'infamous' 99 Disco II for over 2 months now and have only put less than 20 miles on it.
I have changed:
Water Pump
Thermostat
Head Gasket
Head Bolts
A/C Condensor Fan
Engine Fan
Couple of hoses
and had checked:
Radiator
Heads
So, I have to do the worse - well 2nd worse thing, worse being to sell it, and that is to have it towed to the dealer....
It just WILL NOT stop overheating!!
I live 2 1/2 hours from where it is parked (at a family members house) and the nearest LR dealer is in Peoria (20 miles from the Rover - almost 3 hours from me!!) and they are ONLY open on weekdays which makes life that much more fun!
I will get it to them next Thursday and they will do an engine test and probably pressure flush the coolant out.
I am hoping they find out why it is still overheating. I cannot think of anything else to do except replacing the engine.....
We shall see!!
Old Jun 4, 2010 | 04:25 PM
NiteTrain's Avatar
have you did a coolant pressure test?
Old Jun 4, 2010 | 04:26 PM
Jordanmd88's Avatar
Find a good independent shop near you... Don't waste time and Money at the dealership ...
Old Jun 4, 2010 | 04:57 PM
Why a Dealer, that is by far the worst thing you could do.
Just find a shop and have them do both a coolant pressure test and a chemical block test, this will tell you all you need to know.
Old Jun 4, 2010 | 05:02 PM
Eak69's Avatar
Maybe I didn't make myself clear:
Where my car is parked - there is NOTHING in a 50 mile radius that knows ANYTHING about Land Rovers.
If it were up here in Chicago - it would be a different story.
I HAVE to go to the stealership - I have no choice!!!
Also, they are pretty cheap (believe it or not) compared to the LR Dealerships up here in Chicago.
Old Jun 4, 2010 | 05:32 PM
greenwade's Avatar
Find someone who has worked on buick v8s....
Old Jun 4, 2010 | 06:07 PM
d2luvr's Avatar
I'd borrow a buddy's full size truck and rent a trailer to haul it to someone I trust to work on it. Dealerships are clueless (IMHO). I just had mine in the body shop for a nose job and it took LR Indianapolis more than a week to respond to the request for parts and then I had to wait for them to order the stuff. Left me with a very bad taste in my mouth. And so much more appreciation for AB and the other suppliers we all trust.
Old Jun 4, 2010 | 06:57 PM
Rovin4life's Avatar
We had a disco two do the same thing and after every part in the world minus a radiator, we cleaned out the radiator and cleaned out the lines with a hose worked like a charm.
Old Jun 4, 2010 | 09:38 PM
http://www.robisonservice.com/articl..._march2006.asp
http://robisonservice.blogspot.com/
Old Jun 11, 2010 | 11:05 PM
Eak69's Avatar
OK - had it towed to the Stealership and they ran the chemical test for exhaust in the coolant - and... there is exhaust in the coolant.
He said there is most likely one - if not two sleeves that either went bad or dropped - and he would know which ones for $550... I said 'if you know that the sleeves are bad - why waste the time pulling heads (again)?'
He offered to replace the engine for $3600 - but I told him I can get an engine at a fraction of that price and do it myself....
So - I guess the mystery is over and now I have to go shopping for an engine.
Thankfully I have a fully loaded garage that I can do this at.....
