Finally an issue with my inline thermostat mod
So I have a 180 thermostat (failsafe). Since I installed this mod I have had nothing but great results staying at 175-182 even on high steep climbs and stressing my rig on 4 low. Hot day, Wheeling with AC on no problems. Went wheeling this weekend to Lake Tahoe to play in the snow, all day no problems no issues. On the way back home since it's all coasting downhill with very little acceleration I noticed my temp starting to drop drastically. Went all the way down to 145. As soon as it flattens out and I have to give it gas the temp climbs nicely back to its 175-182 normal operating temps. Start to coast downhill again same things starts happening. Mind you this is a long hour 45-1 hour of coasting downhill then flats. Anyone else have this problem?
But that really doesn't make sense because if you did the traditional setup your thermostat would be at the front and would be closed at that temp, holding hot water toward the temp sensor.
I'm stumped. Or maybe I'm close. I can't tell which.
Thermostat is stuck open.
Long periods of low engine load coupled with a large amount of airflow across the radiator with a thermostat that's stuck open and constantly flowing coolant into the radiator, and you'll definitely get that effect.
If you were here in the northern states, the cold weather alone would keep you well below 180ºF.
That's what I thought but if it was stuck open it would have the same effect at idle right? Also take a long time to warm up. None of which are happening. I'm pretty sure the thermostat is working because the temp still did its normal climb... 173-181 then Goes down slowly back to 173... rinse and repeat.
Either way it's also what I was thinking but I have not even put 3k miles on the mod.
That's odd. I'm no expert but I think the coasting had your water pump turning very slowly and the cold air was causing the sensor to read a lower temperature than true.
What you experienced going downhill in cold temp is very normal, and it will happen in any car, I have experienced it with many different cars, & it's due to radiator getting cold & engine not making much heat, because there is no load on engine, basically not burning much fuel because weight of car is pushing it downhill, your T-stat is not stuck open yet,!! & nothing wrong with it,
being a failsafe it has a built in feature, if it overheats once it will open fully & the small extended arms in T-stat will lock it so it won't have a way to close again, but your obviously works fine since you get normal temp in other conditions once not going downhill any more,
(Failsafe being a MOTORAD does really need this feature, because they are known to fail often,! LOL,,)
Thanks for the reply and letting me know this has happened in other cars. Being from San Diego and recently moving to colder climates I've never had these types of issues before.
