Finding the nipple
Old Sep 3, 2018 | 09:31 AM
zuke's Avatar
Default Finding the nipple
I need to find if any of my discos have a locking cdl . 02's and one 03. I have the 04 linkage and stuff so just want to swap it into the easy one
Old Sep 3, 2018 | 11:43 AM
Friday Night Disco's Avatar
Do you have the build dates?
Best4x4's Avatar
Gotta crawl under your D2 grab a telescoping mirror & you should see the nipple surrounded by 3 10mm bolts that hold the plate into place on the TC. If the area is 100% flat directly ontop and just behind where the front driveshaft sits = No CDL. The 02 is a 50/50 shot depending on the build date if it’s an early 02 made in late 01 chances are it will have the CDL nipple, if it’s late 02 & up I doubt it. The 03 certainly won’t unless someone replaced the TC at one point.
Old Sep 3, 2018 | 11:46 AM
To be clear, my 02 was built in Dec of 2001 and had the nipple. I believe any D2 built starting in Jan 02 does not have it.
Old Sep 3, 2018 | 12:05 PM
tcr6v1's Avatar
The 03 went have it but you can check the '02s
this is what you are feeling for directly on top and back of the front output shaft
yours wont have that flat peice bolted to it, just the nut
Old Sep 3, 2018 | 12:25 PM
Twix's Avatar
I hear it's an absolute crap chute. Nobody seems to have a definitive answer, including Land Rover.
Old Sep 3, 2018 | 01:01 PM
Best4x4's Avatar
I've owned 3 02's and they all had CDL nipples. I think it's after like 3/02 that LR completely ditched CDL equipped TC's until late 03 (sold as 04's) and of coarse the final 04's.
Old Sep 3, 2018 | 09:50 PM
mln01's Avatar
I've found that if you gently kiss and nibble the neck of your Rover the nipple will become quickly apparent.
Old Sep 3, 2018 | 10:22 PM
Dave03S's Avatar
I was waiting to see who would go first. Well played.
Old Sep 4, 2018 | 07:15 AM
JUKE179r's Avatar
