Which first: Brakes or Tires?
I've been hit with a serious dilemma here: Both my tires and brake are in dire need of changing. My brake pads are completely worn and my rotors so warped they can't be smoothed down. My tires are so bald and unbalanced my Disco vibrates like a personal massage chair on high! Problem is I don't have the cash to do both first. So which one do I start with? (Recently bought an engagement ring that's why I have no cash hehhehhee)
Or, you can find a $3-400 beater on craigslist and drive that around so you don't have to worry about tearing your Rover up!
Too bad you're not closer. I have 7 235x70 R16 XPC Michelins I want to get rid of cheap.
http://atlanta.craigslist.org/pts/1238720605.html
Those are the tires that I was looking for but could not find to save my life.
If I had the money I would still but them.
I figured it would be better to get brakes first then tires. I just don't like driving the Disco around because the vibrations are getting worse and worse it seems like. Brakes aren't as bad as I make them out to be but they definetly need to be changed out. Would rotating and balancing the tires make any difference?
