First oil change
First oil change
I am doing my first oil change since buying the rig used, and I am unsure as to what type of oil they had used in it. I want to follow the advice given to use Shell Rotella t6, but if I have conventional oil in it now will it mess it up? I can't do an engine flush before I do the oil change, unless it will only add 30 minutes to the process. Please help.
Thanks Mike. Tomorrow is an oil change and plugs and wires.
Payday will bring a new front drive shaft (trying Dynamic Drive Line's offering, per another user's recommendation).
I still need to change fluids for t-case, diffs, power steering, transmission, and brakes.
After that, it will be a coolant system flush and a new thermostat and pressure cap.
this is a lot of work, but I am hoping to keep this thing forever.
Other projects include: looking for jumpseats for an SE to SE7 conversion, gluing down the rubber seal on the lower windshield (broken cowl doesn't worry me at much as the rubber peeling away from the glass).
