First time off-road
Old 10-01-2018 | 12:15 PM
redwhitekat's Avatar
As of now my truck is running perfect no lights etc maintenance all done and it's purring like a little kitten
Old 10-01-2018 | 12:36 PM
tcr6v1's Avatar
I have a gas tank skid, steering skid, both diff skids and a steel bumper... are they worth it? Depends what you consider off roading. If you are only driving washed out fire roads you'll be fine without any protection or even a lift. I do a bit of crawling and beat the ever loving s*** out of my truck so in my case the protection is worth it.
a winch is worth it if you ever travel alone on questionable roads but it doesnt sound like you are getting too far off the path so you'll be fine without one.
Old 10-01-2018 | 09:54 PM
Diff guards are cheap protection. Also a ton easier than replacing a axle housing due to the ring gear eating a whole in the cover. Want to know how I know that?
Old 10-02-2018 | 03:21 AM
The Deputy's Avatar
A lot of great advice from Richard...and l agree...if you are mainly traveling forest service roads and two tracks with others...a stock Discovery (with working TC) will do the job fine. And even in areas where it gets a little more advanced...they can make do and even surprise you at times. Especially, as your experience level increases.
But, unlike Richard...l'm still a young man, in the prime of my life (58...lol) and do not like to say..."the trail ends here for me today". Especially, since l hate backtracking . But, during my last outing, solo, encountered about seven 10 inch diameter dead falls laying criss-acrossed in a swampy area. Could see where others were rerouting along a high bank ridge to the right, but you're not legally suppose to leave the trail here in Michigan. So, after smoking a cigar and pondering over the situation...the rover did a five-point turn. If l'd have had a chainsaw...the end result would have differed. Because, l had the right amount of recovery gear (winch, axe, hand saw, straps, etc) to get me through.
One thing l do a lot of...is getting out and walking the trail. This helps immensely, if you are wheeling alone.
Brian.
Richard Gallant (10-02-2018)
Old 10-02-2018 | 05:35 AM
Fastercat's Avatar
Red white cat where did you go wheeling? Did you go with the Ontario Land Rover group?
Old 10-02-2018 | 05:54 AM
Yes up by parry sound
Old 10-02-2018 | 09:49 AM
Fastercat's Avatar
I’d recommend skid plates and diff guards for that area. I used to go there quite often in my Jeep days. Did you guys run the power line trails? How is the club? In there site pictures I see mostly defenders. I’d love to go up there again but with 3 kids and hockey season on it’s hard to get away now.
Old 10-02-2018 | 10:11 AM
From what I was told the trail is a lot easier now. The power line guys are doing a lot of work the killing the trails. But there was a few rock areas that you had to go very slow and pay attention
there was a reporter doing a story for Land Rover 70 th anniversary and I should have some good pics soon
all the guys have defenders I was the only disco
Old 10-02-2018 | 10:13 AM
Here in Canada you barely see any discos or landrover in other off-road groups. Mostly jeeps and some toyotas. Specially the discos are non existing on our trails. Like I said the Land Rover clubs mostly use defenders
Old 10-02-2018 | 10:25 AM
Richard Gallant's Avatar
But, unlike Richard...l'm still a young man, in the prime of my life (58...lol) and do not like to say..."the trail ends here for me today". Especially, since l hate backtracking . But, during my last outing, solo, encountered about seven 10 inch diameter dead falls laying criss-acrossed in a swampy area. Could see where others were rerouting along a high bank rig to the right, but you're not legally suppose to leave the trail here in Michigan. So, after smoking a cigar and pondering over the situation...the rover did a five-point turn. If l'd have had a chainsaw...the end result would have differed. Because, l had the right amount of recovery gear (winch, axe, hand saw, straps, etc) to get me through.
Brian.
Great minds, that is my solution too have a good cigar, a cup of coffee, grab the 12 gauge & bear spray and walk 200 - 300 meters down the road to see if things get worse. And every now and then they get way worse.
The Deputy (10-02-2018)
Quick Reply: First time off-road
