Fitting 245/75/16 tyres to 2004 Discovery 2
Old Dec 19, 2024 | 10:19 AM
Archieboo62's Avatar
Thumbs up Fitting 245/75/16 tyres to 2004 Discovery 2
After ENDLESS research and enquiries, I finally bought and fitted 245/75/16 tyres in place of the recommended 235/70/16. I just want to share pros and cons with other Discovery 2 owners. The windscreen headlight and window spray bottles( on the passenger side of right hand drive vehicles) sometimes sag and move closer towards the tyre than originally designed. The brackets are a bit flimsy. I re-set the brackets and moved them as far away from the tyre as possible. Initially the tyres touched when on a sharp turn. Now it is no problem. Pros...definite increase in diesel consumption efficiency on the TD5. No noticeable dicrease in power whatsoever. A smoother ride due to the increased 70 to 75 profile. A much more sensitive feel to stering without it becoming dodgy at speeds over 120. VERY safe. I amextremely happy with my decision. I work in the automotive engineering field, and my gut feeling is that this diameter is absolutely on the spot.
Old Dec 19, 2024 | 11:23 AM
Brava's Avatar
That's the search I'm on now. Do you have any photos you can share of the new set up? Thanks in advance
Old Dec 19, 2024 | 11:39 AM
disco96sd's Avatar
120mph - where did you do that ? on the autobahn ?
Old Dec 19, 2024 | 12:24 PM
jastutte's Avatar
tires spelled, tyres and a TD5 engine.
maybe, 120 kph. i hope.
Old Dec 19, 2024 | 08:29 PM
AjjayS's Avatar
I also have the Same size tires, no lift or anything and can confirm at least for me with a LHD truck there's no rubbing or anything. And it handles quite nicely even past 150km/h, though I don't recommend going much faster.
Old Dec 19, 2024 | 08:36 PM
Harvlr's Avatar
Yeah, 120 mph in my P38 would probably feel good but 120 kph in the D2 would be pretty fast.
disco96sd
Oct 22, 2022 10:18 AM
disco96sd
May 29, 2022 09:52 AM
diggerod
Oct 29, 2017 11:57 AM
JamesDisco97
Oct 12, 2011 09:48 PM
