Fitting a winch - spring upgrade
It's still on standard suspension for now but the winch is in. It's a "rugged Ridge 8,500lb winch which I picked up at an attractive price from Icon 4x in Dubai. Fitting was fairly straightforward: the mounting plate needed a little "adjustment" with an angle grinder in order to get it to fit around the steering guard brackets but it fits nicely below the main bumper bar and in front of the radiator and aircon condensor. A little bumper trimming was required, not a problem as the bottom of the bumper was already broken, and it now looks neater anyway. The steering guard plate has been removed because it clashes with the winch mount - it will need to be trimmed to fit. however, in the meantime a temporary aluminium checker plate panel is in place.
The control box is mounted on a bracket in front of the aircon cooling fan - but the box is mostly in front of the fan motor body and should not significantly reduce the airflow. The remote control plugs in on the front of the box and the plug is accessed through the slats in the grille.
drowssap (01-09-2015)
southfloridadiscoII
06-18-2009 08:48 AM
