Flashing Speedometer
Old Dec 29, 2011 | 03:43 PM
mydisco03's Avatar
Default Flashing Speedometer
Hi There Guy's!!! Today I disconect the speedometer on a D2 a 2001 and So the litle digital window were u can read the miles now those numbers are flashing or blinking.... Any Ideas? I try unpluging the battery but still the same.... HELP!!!!!!
Old Dec 29, 2011 | 04:41 PM
jafir's Avatar
It thinks you are a being deceptive. The miles on the odometer and BCU don't match. It thinks you might have tried to put a lower mileage odometer in it. You'll either have to have it synced with a VERY fancy computer, or you'll have to have the flashing turned off with a fancy computer.
Old Dec 29, 2011 | 05:21 PM
ebg18t's Avatar
So what you are saying is he needs a fancy computer .
Old Dec 29, 2011 | 05:38 PM
jafir's Avatar
Or just ignore the blinking. If it's like any other D2, the bulb for the back light will burn out eventually, so you'll only see it in the daytime.
Old Dec 29, 2011 | 06:43 PM
Its not the speedometer that is flashing, it is the odometer.
Old Dec 29, 2011 | 07:42 PM
mydisco03's Avatar
Yea it is the odometer that blink, Not the lights... It happen when I disconect the gauges to put L.E.D lights in there.. When I hook everything back and turn the key, Blink but the miles and everything work.. " Just blink" Any Idead on how to fix's that?
Old Dec 29, 2011 | 07:53 PM
mydisco03's Avatar
If thats the case, Where can I get that fancy computer. Whats the name and price range? Also where can I get it? Thanks Guy's!!
Old Dec 29, 2011 | 08:38 PM
jafir's Avatar
Is it still showing miles?
Old Dec 29, 2011 | 08:42 PM
You must take it to the dealer to have the BCU and the OD paired.
Old Dec 29, 2011 | 08:49 PM
jafir's Avatar
Some have reported flashing along with the units getting changed from miles to kilometers. Not sure if that would cause the blink or if whatever caused them to be unsynced also caused it to switch to km.
If you are seeing the wrong units, you could try switching it back and seeing if that fixes it. Not sure.
