Fluid From Behind passenger rear brakes. Any idea
Old Jan 21, 2011 | 03:44 PM
FightOnUSC79's Avatar
Default Fluid From Behind passenger rear brakes. Any idea
Looks like it would be brake fluid but it is not. I am thihnking something along the lines of a seal onthe hub? or maybe i am wrong. I will pull it apart this weekend and check it out, but wanted to know what i should be looking for.
Thanks in advance
Old Jan 21, 2011 | 07:55 PM
Leaking axle seal.
It is the seal that goes between the hub and the axle.
Its a $.98 part.
Before you tear it all apart make sure your axle breather is not clogged.
If the diff gets over pressurized it will force gear lube out the seals.
Old Jan 21, 2011 | 08:02 PM
Originally Posted by Spike555
Leaking axle seal.
Its a $.98 part.
Thanks for the heads up. I'd hate to have torn it down for it to be something small.
Old Jan 21, 2011 | 09:53 PM
bikingteacher's Avatar
Spike, didn't I see yours in the shop this summer for that very thing?!
Old Jan 21, 2011 | 11:39 PM
NiteTrain's Avatar
$.98 O-ring seal or $400 unit bearing..I'd start with the o-ring some fresh gear oil and lucas hub oil might help too
Old Jan 22, 2011 | 07:58 AM
Yes.
I had a ripped hub oil seal.
On the DI there is a seal that goes between the stub axle and the hub assembly.
2 years ago when my wheel bearing welded itself to the stub axle it had to be ground off and this left a small bur on the stub axle.
You cannot see the bur but you can feel it with your finger.
Eventually it ripped the oil seal.
I had to replace the stub axle and the oil seal.
I still have my old stub axle, it makes a very nice paper weight.
Old Jan 23, 2011 | 06:04 PM
Leaking axle seal.
Its a $.98 part.
Checked the axle breather and was able to blow into it and air moved so I'm on to the seal replacement. Unless anyone has another direction to move in?
Thanks for the help
Old Jan 23, 2011 | 07:34 PM
NiteTrain's Avatar
the best place to pick up the seal is at a dealership if there is one close to you..only $1..probably the only thing there for $1 lol
Old Jan 23, 2011 | 11:06 PM
I'm going to take a crack at it next weekend. In the hopes it's just the seal and not the hub itself is there anything I should be looking for or do while I have it apart?
Old Jan 24, 2011 | 07:57 PM
If I get this thing apart and it is a hub as I have read quite a few bad stories about it being this issue and a new hub being the remedy. Would I need to buy the complete new hub (AB $400) with abs sensor or is this something I can trust to get from a local dealer who has a used, but warranties hub although without sensor for $150.00 and buy the sensor for 50.00 saving a bit of change?
