Fluid on the drive/cold lower rad hose
Old Jul 15, 2008 | 11:26 AM
Roveroh's Avatar
Default Fluid on the drive/cold lower rad hose
My DII 2002 with 83,000 mi leak radiator fluid overnight. I added some water to the resivour (sp) and my wife ran to the store. No visable leakage after the drive. Checked the hoses, the top were hot to the touch, the bottom was warm, but not hot. Their seems to be a white plastic housing tee that connects the lower and upper hoses- is that the t stat. The trucks temp runs in normal range- no visable leakage from radiator hoses. Could it be a pinhole leak in the radiator?
Old Jul 15, 2008 | 12:58 PM
98roverguy's Avatar
Default RE: Fluid on the drive/cold lower rad hose
Do a pressure test on it.
Old Jul 15, 2008 | 02:17 PM
okdiscoguy's Avatar
X2, it could be leaking anywhere, do a pressure test.
Old Jul 15, 2008 | 08:25 PM
NiteTrain's Avatar
autozone has a pressure test kit they loan out...but they did not have the adapter for my bwm.
sickws6
Aug 1, 2013 09:48 PM
LADEROUTE
Sep 1, 2012 05:06 PM
Riveter
Aug 6, 2012 06:59 PM
XCELLER8
Jul 16, 2011 12:56 PM
Northern Land Rover
Aug 11, 2010 08:25 PM
