Fluids
Old Jan 26, 2009 | 10:06 PM
lrd2's Avatar
Default Fluids
am about to do a full service on my truck and was wondering what name brand fluids should i use for the power steering fluid and the brake fluid i saw one on AB.com but not sure if its synthetic
Old Jan 26, 2009 | 10:08 PM
lrd2's Avatar
Default RE: Fluids
also what type of transmission oil should i use
Old Jan 26, 2009 | 11:14 PM
hazletbassist89's Avatar
Default RE: Fluids
Pretty much any big brand full synthetic should be fine. For transmission fluid I'm using Valvoline high mileage.
Old Jan 27, 2009 | 10:22 AM
Default RE: Fluids
Royal Purple, Mobil 1, Red Line or any of the major synthetics, as already mentioned Vavoline makes a great high mileage Dextron 3 as well as a great synthetic brake fluid.
If you can, use a Mobil 1-301 or a K&N 3001 oil filter, only use a factory paper air filter.
What other services are you doing?
Old Jan 27, 2009 | 11:21 AM
lrd2's Avatar
Default RE: Fluids
mike do you mind if i give you a call i want to ask you a couple of questions before i order parts.
Old Jun 9, 2009 | 02:40 PM
CampCobb's Avatar
I am having a tough time finding any brand of power steering fluid that is synthetic. any help here on where to buy? thanks I have checked Pep Boys, Auto Zone, Advanced Auto and O'reileys.
Old Jun 9, 2009 | 03:52 PM
You dont have to use full synthetic.
Is yours a DI or a DII?
Old Jun 9, 2009 | 04:08 PM
humroot's Avatar
I found my Royal Purple at a speed shop. Pep Boys carries the engine oil and tranny fluid, but I had to go to the speed shop for brake and ps.
Old Jun 9, 2009 | 04:22 PM
Redline has it, i believe, Some stores still have inventories of Vavoline's synthetic p/s fluid.
As Spike has mentioned, you don't need it but it is a plus if you can find it. If not consider adding a bottle of Lucas p/s additive if you do a full flush.
Old Jun 9, 2009 | 04:54 PM
CampCobb's Avatar
Its a DII by the way with ACE. I was planning on running synthetic w/Lucas but if you think regular ps fluid w/Lucas is ok then I'll do that. Thats okay with ACE, right?
