flushed radiator/chk engine light
Old Apr 5, 2014 | 06:14 PM
jeffmcdaniel's Avatar
Default flushed radiator/chk engine light
I flushed out my radiator, did it correctly. Started it up and now the check engine light is on. How do I get it to turn off?
Old Apr 5, 2014 | 08:30 PM
ralphobell's Avatar
You need an OBD2 code reader, one that will reset the codes. Can't help until we know what the code is. Most autoparts stores can scan for the code but most likely will not reset it.
Old Apr 5, 2014 | 10:40 PM
zeroone's Avatar
I am gonna recommend you get an ultraguage when you can. Best $89 bucks I spent on the dawn discovery, lol. Never hurts to have a unit that reads live data. Especially in these things.
Old Apr 5, 2014 | 11:40 PM
Wow just a obd2, I thought I would have to get some special Land rover only reader for $500. Ok my friend has one, il find out tomorrow morning.
Old Apr 6, 2014 | 07:03 AM
jfall's Avatar
Turn on the key.
Plug in the reader.
Take a picture of the screen with the codes with your cell phone cam.
Clear the codes.
That's it.
Use
http://enginecodemaster.com
If your scanner does not say what the codes mean.
Old Apr 7, 2014 | 12:17 PM
I read the code, it was a misfire in cylinder one. the boot was pulled back a bit and it arked to the fiberglass wrap. Pushed the boot down, cleared the code and drove it 30 miles. All is back to normal. Now the daunting task of changing the plug wires.
jacobmm
Jul 15, 2016 04:38 AM
jaydog101
May 8, 2011 08:36 AM
sloppyjoe
Aug 13, 2009 06:04 PM
Frank4
Mar 15, 2009 07:42 PM
213solider
Jun 13, 2006 07:00 PM
